For the AD0802 watch, press MODE until the standard time appears, then press START/STOP to set the time and date. In that state, press RESET to change the current setting (hold it to scan values) and MODE to move to the next setting (seconds, then hour, minutes, year, month and day of the month in that order). Press START/STOP again to exit time setting mode. At any time while in time-setting mode, you can press the LIGHT button to toggle 24hour time on and off (the 24H indicator will turn on and off to show the current mode).
I contacted both the eBay seller of the watch and the watch maker and what I got back was a complete joke so I figured it out and made my own manual but there doesn't seem to be any way to attach it to this posting.
I have not been able to find the instructions for your watch but most watches operate in a similar manner so try the following (some experimenting may be required).
The settings are changed by pressing the "MODE" button several times until you reach a setting that says something like "24".
Now try pressing the "ST/SP" to change to "12" , if this does not work, press the "RESET" button.
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
in normeal time mode...Push silver button on lower left of watch 3 times, seconds start flashing. push lower right silver button 2 times hour starts flashing. push upper right silver button until you scroll through the time desired, either A, P instead of H for military time.
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
