Want the wiring diagram
Without wiring diagram i can tellyou what you need to know. start with the red wire it is your switched power wire meaning when your key switch is on you will havee power when the key switch is off you will not have power. Next wire is you yellow wire which is memory it is a constant power wire meaning it should have power all the time key on and key off. next is the black wire which is the chassis ground. Now you should have a set of green wires and a set of purple wires these are your front speakers left and right. next you should have a set of grey wires and a set of white wires they are your rear speaker wires left and right. subwoofers hook up through the rca connectios which are the red and white circles on the back of the radio red is right and white is left. ps. no bare wires touch metal when power is on. good luck
