My soap will not come out of the hose. The pressure washer is working fine. However, the hose for the soap will not **** up the soap. What do I do?
SOURCE: It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Testimonial: "Thanks for your help, I will give that a try."
SOURCE: I have a Troy-Bilt pressure washer #020344. When
There is a check ball and spring within the soap dispenser that may be worn or lost. Easy fix however. If the parts are there and installed correctly, seat may be worn. If parts are missing or valve worn out, just plug the valve and purchase an aftermarket dispenser to install in the line between the pump and hose (not expensive and ez to do. )
good luck
