Error Code 20 on a Noritz tankless water heater (model EZ98DV) is typically associated with an issue with the "priority" function, which is a feature that allows the water heater to prioritize certain uses of hot water over others.
When the "priority" light is flashing and error code 20 is displayed, it typically means that there is a problem with the priority function and it needs to be reset.
To fix this issue, you can try the following steps:
- Turn off the power to the water heater by turning off the circuit breaker or removing the fuse.
- Wait for about 10 seconds and then turn the power back on.
- Press and hold the "priority" button for about 5 seconds, until the "priority" light turns off.
- Turn the water heater back on and check to see if the error code has cleared and the "priority" light is no longer flashing.
If the error code 20 still appears and the priority light is flashing, it's best to consult the manual or a professional technician to diagnose the problem.
It's important to note that the error code 20 can also be caused by other issues such as, faulty thermistor, faulty thermistor harness, faulty PCB, etc. So, it's best to get it checked by a professional.
