Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
Posted on Apr 22, 2010
Cant retune to pick up dvb samsung le 26r74bd
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
179
Points
Hi return the TV with out the aerial connected and wait until it finishes then plug the aerial back in and try again. Let me know how you get on.
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
Pink 19" Soundwave Widescreen LCD TV with DVD and DVB
When you retune your TV to freeview make sure you SAVE settings
My 19" Ferguson F1950LD has
Go to Menu, DVB, configuration, installation, select auto. Hope that helps
2helpful
2answers
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Every time the machine is switshed on it indicates that a new DVB service has been found. This suggests it is not storing this info when it does receive it - any suggestions?
Unles you add the new channel(s) each time, it will flash the message. Go into the tuning menu and either add new channels or retune completly.
1helpful
It says dvb-t module not working
its because u need to reset it and if that dont work take it back and dont get the same one...
3helpful
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
3helpful
Loss of BBC channels
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
5helpful
I NEED TO RETUNE THE FREEVIEW ON MY DUAL DDLCD1905 TV
If you havent already. Select DTV from the source menu.
then press the DVB button on the remote and choose system setting.
Select First Time Installation to reset all DTV channels
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
