SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Error code C-D351 on a Bizhub C250
are you sure that you have a correct model and malfunction ccode ??? i cant find this code on bizhub C250
I HAVE ERROR CODE IN BIZHUB 600
