Question about Kyocera CS-2550 Black and White Copier
I try to connect a kyocera km 3060 to scan to pc but i forgot the steps?
You will need to download the software and drivers to connect the Kyocera 3060 to your PC. Click on the links below and select your operating system to get started
http://www.kyoceramita.eu/index/service/dlc.false.driver.KM3060._.EN.html
Now download the software at this link
http://www.kyoceramita.eu/index/service/dlc.false.utility.KM3060._.EN.html
Posted on Apr 22, 2010
6ya staff
SOURCE:
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
Why does the Kyocera KM-3060 Freeze at "Program Loading"
the firmware needs to be updated with the full version overwrite not turbo upgrade
Jul 28, 2014 | Kyocera Km-3060 Mfp Copier Copy Machine...
How kyocera works
developer and toner are two drifernt things you have to check to see if the developing unit is installed correctly
Jul 27, 2014 | Kyocera Km-3060 Mfp Copier Copy Machine...
How do you keep people from being able to use the maintenance key on kyocera km3060
Change the admin password on it. Or if not feasible, then put a sticky label over the button.
Nov 22, 2013 | Kyocera Km 3060 Digital Copier With...
Not scanning...error code 720f
Software trouble error code
720f Error: Unknown error
Causes:
Unable to determine the
cause.
Check procedures/corrective measures:
Turn the main power switch off and on.
Jan 14, 2011 | Kyocera Km-3060 Mfp Copier Copy Machine...
Our computer maintenance company was able to set up our scanner about three months ago. Over the weekend we have lost that capability. We are receiving an error message: Setting how do I fix scanning...
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
Dec 20, 2010 | Kyocera Km-3060 Mfp Copier Copy Machine...
Kyocera CS-2550 Black and White Copier Logo
90 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
