Nikon N80 takes one shot, then battery indicator starts flashing for about 10sec. Camera won't autofocus during this time. Afterwards battery indicator stops flashing and camera operation is back to normal. And this 'cooldown' happens after every shot. I'm using grip with fresh set of batteries.
If your batteries are fresh ( have seen flat new ones older stock) and are using alkalines then I would think you have a connector problem. Can you check and clean the connectiosn inside the grip and on the camera body. I've also seen dirty lens contacts and even a sticky shutter cause this. It's usually not serious just rather annoyng until you find it.
To check the shutter and mirror you just need to take the lens off to expose them. About all you check for is free easy movement.
Unfortunately if the power off 'resets' it I have a feeling this may be a board problem in the body. That upgrades it from annoy to a pain. That is generally not a user repairable item. So you may need to find a camera tech or shop and take it in.
You're right - it is annoying. A piece of additional info - if I power the camera off during battery indicator flashing and power it on again - it's operational right away.
Power contacts are clean and shiny. Same for lens contacts. Cleaned them once more just in case. Problem persists. How do I check for a sticky shutter?
