HP PSC 2210 All-In-One InkJet Printer Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink cartridge When i put in a new ink cartridge it says to press enter but when i do it says alignment failed, What is the problem?
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Apr 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130437
Points
8732
Try pressing the new cartridge onto a damp paper towel. Look for all colors to make a streak on the towel, if any color or black is missing it won't pass alignment. It won't pass alignment or let you print until you get all the colors working.
11helpful
My printer is telling me to "press enter to align the cartridge". i did that but, nothing is happening. HELP!
Solution There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Follow the steps below to resolve the problem Step one: Examine the paper the alignment page was printed on The alignment page must be printed on clean plain paper of either letter or A4-size and that has a brightness level (as printed on the paper package) of at least 85. Colored papers or paper that already has printing on it will cause the alignment to fail. Back to top Step two: Does the alignment page print correctly For the HP PSC 900 series, if the page ejects immediately or a Paper mismatch or Paper too narrow message is displayed, the 4 x 6 paper tray selector located on the paper output tray is pushed forward. Move the selector all the way toward the front of the product. Look at the alignment pages that the product printed. Compare the alignment page to those that are included in the "Examples of alignment pages" section in this document. If any of the colors or the black is missing from your alignment page, a cartridge-related problem exists. Click here for information about troubleshooting ink- and cartridge-related problems (buu02176) (in English). Back to top Step three: Perform an print cartridge cleaning procedure The product can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
  1. On the front panel, press the Menu or Setup button (depending on the model).
  2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
  3. The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem. Back to top Step four: Try to align the page again HP products have two methods for aligning the ink cartridges, fully-automatic and semi-automatic. The steps are different for each type. Refer to the information below to determine which alignment method your product uses. Automatic cartridge alignment Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
I just changed my black ink cartridge and I keep getting a message that reads: pree enter to align catridges. Each time that I press enter the test runs and the screen reads alignment failed. HELP
Hi
in order to get alignment you need to have ink
in both cartridges
You need to replace and color cartridge or refill it
like this
If I help you pls vote me
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
2answers
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
2answers
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
1helpful
3answers
It will not align ink cartridge
the printer keeps saying "press enter to align cateritage" so i press enter. there was no black ink so
I went to the printer store and bought a refill on black ink...
Put the refilled cateritage in the printer and again its says allign cateritage. It takes about 5 minutes, and it prints out a piece of paper and says alignment failed....
How can i fix this occuring problem?!?!
Thanks
k24674
Grand Canyon Tech
Grand Canyon Tech
