How do I get the back off my Timex Indiglo to change the battery? There is a small tab that looks like it might be the place to pry the back off but I can't get even the finest tool in there to do so.
There is a special caseback prying tool for that purpose. You can find them on ebay for a reasonable cost but you just might want to let a watch shop do it for you to avoid damaging the watch. Also, once you get it off, you have to get it back on which may require the use of a case back pliers designed to prevent damage to the crystal when seating the caseback, You will also want to replace the rubber gasket on the caseback to keep it water resistant. Even if it looks OK, the gasket should not be reused as once it has been compressed and removed it will not seal properly and allow dust and water to enter. Most shops, including Sears, will change the battery and gasket for about $8 while you wait.
