Oster 4134 / 4126 Classic Beehive Work Top Blender Logo
Posted on Mar 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rarely used Sunbeam Blender Model #4181 stopped working
I was using my blender (for the second or third time EVER) and it just stopped working. I noticed a little smoke just before that happened, so I turned it off, waited until it cooledOFF, and tried again. It worked for just a second or two then it just stopped!! Did I permanently burn the thing? Is there anything I can do to check if it is repairable before I "toss" it?
Anonymous
Level 2:
Novelist:
  • Expert 142 Answers
  • Posted on Mar 24, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
142
Questions
0
Helped
88917
Points
347
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
Oster blender pro 1200 stops prematurely and 2 present lights blink 3 times
It sounds like overheating or a control board failure. Contact the maker for a warranty claim
https://www.google.com/search?q=Sunbeam+sfs001+manual
I need a replacement jar for a sunbeam 4181 blender
Hello, devihunt
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
1helpful
Where can I find a gasket for Sunbeam 2774 blender???
If you cannot find one, well in the "Old" days we used to make gaskets out of Thick Brown Paper Bags. Using the OLD gasket as a template simply trace around it & cut it out. Lightly Oil it and use it as normal. Usually works great, sometimes you need two, to get the thickness.
1helpful
2answers
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jeff Gordon Blender blew up
Sorry to say we do not repair. You will have to contact sunbeam here at this link for service.
http://www.sunbeam.com/index.aspx?section=kitchen
Good luck and Please Rate FixYa1!
5helpful
2answers
Sunbean Blender Liking problem
I have a better than original seal made of a material approved by the FDA. Let me know if you are still interested.
Cheers,
JJ
2helpful
2answers
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
1helpful
Blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Top Oster Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Joaquin A Barahona ...
Are you an Oster Blender Expert? Answer questions, earn points and help others
