HI. This will be the result of a failed touch pad assembly. Use the procedure below to isolated the issue.
1. Once you have gained access to the touch pad assembly, Inspect the keypad connector for firm a connection. The Key pad will be connected to the rear of the man control board. Check the connectors for a firm connection. Move to step two if the connection is secure.
2. Press CANCEL. If the error code returns after 60 seconds, replace your keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Testimonial: "This was the problem. Thank you! Using the self clean option can burn out the control board. "
