Programming is done on M7310, M7324 and T7316 sets. To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344. The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming. At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow) The display should sat LINE ACCESS Press the show key (top right arrow) . The display should say LINE ASSIGNMENT. Press the show key (top right arrow) . The display ask for a line number. press list The display should say line 001: appear only
press the Chng key till it says appear & ring press next key (lower right arrow) The display should say line 002: appear only repeat the procedure the same as line 001 for the remaining ringing lines
Power went out. Phone states "Do not disturb" and it will not ring. Everything else seems to work except I can't press 1, etc. when prompted to do so. Please helpPower went out. Phone states "Do not disturb" and it will not ring. Everything else seems to work except I can't press 1, etc. when prompted to do so. Please help
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
