The dishwasher will go through the wash cycles and gives all indications water is entering and leaving the machine, but the water does not enter the unit.
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
water entering and leaving machine simultaneously
