LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
  • dave Jul 08, 2016
    Sometimes its your main circulation pump if it keeps pumping for sometime then OE appears cause it also sends a message to the water counter or flow meter
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 18, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5037057
Points
35540
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
My lg washing machine is giving a oe code. It will pause it self when it run a little bit and i could smell a burnt smell
https://www.lg.com/us/support/help-library/oe-error-code-front-load-washer-CT10000010-1337714738535
The machine has determined it is unable to drain water. See link.
Lg Manuel for dishwasher 309 1879 Dishwasher stopped and displayed an error message of "OE". What does this OE mean.
OE indicates a drain error. Your model number doesn't fit the usual pattern for LG dishwashers; LDT5665WW and LDS4821WW are a couple of recent model numbers.
To start diagnosing and fixing the OE error, first check the discharge hose. Make sure that it isn't clogged, kinked or improperly positioned. Make sure that the pipe or food disposer that the drain hose connects to isn't clogged. (Check into the rest of the drain pipe if needed.)
Next check that the float switch inside the dishwasher isn't blocked. This indicates the water level and if a foreign object is holding it open, the dishwasher will continue to try to drain the water.
Finally check for any blockage in the drain pump. Also check the pump for obvious damage. If the pump is damaged, replace it.
After you've checked and fixed (as needed) the above issues, try the dishwasher again. If the OE code recurs, then you need to replace the drain motor pump assembly.
If your dishwasher is under warranty, contact LG. Otherwise, please check and post your machine's model number. I can check to see if the parts are available.
I hope this helps.
1helpful
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
3helpful
I have the LG Tromm 27'' Front Loader model WM2277HW
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
3helpful
Getting the OE error message on LG Tromm
9helpful
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
2answers
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
3helpful
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
1helpful
3answers
OE Error
You do not have an "OE" error, it is actually a "DE" error. (Drain error) If after 5 minutes of drain time the pump motor RPM's haven't gone up the dishwasher knows that there is still water in the tub and throws the "DE" error. Often times the problem is the controller, but I have found more often that the problem is a long and/or restricted drain line. If someone had to extend the drain hose to reach a drain the extra resistance from the splice and pushing all the extra water in the long drain line prevents the dishwasher from pumping out within the time limit.
In some cases it is possible to correct this condition by first making sure the drain hose has a high loop to prevent siphoning, then running the drain line through the floor and into an open trap. (again, to prevent siphoning) Do not use extensions on the dishwasher drain hose supplied with the unit.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
