My Daughter has a Dell Latitude D600. About 2 weeks ago it became very hot on the bottom right hand corner of the screen surround causing a small area of the screent to change colour. After leaving to cool and then re-booting the problem had disappeared.
Then the screen started going dark, a faint image still visible. Now the screen only comes on for a few seconds at boot and similarly a few seconds on depressing the lid closure switch.
Is thsi the backlight or inverter that is failing?
The picture board on your monitor is faulty or bad, since it goes
black after few seconds, it means the
board of your laptop has developed fault.
The best thing for you
to
do now is to take the laptop to a local repairer within your vicinity
to help with the replacement of the picture board
because the fault is not something you can fix yourself. in order not to
complicate issues.
Take care.
Testimonial: "Thanks for your advice. I will change the inverter"
If I plug the laptop into a monitor the image is fine and there is a faint image on the laptop screen. Doesn' t
Doesn' t this indicate the backlight inverter is faulty?
