Honeywell Heat/Cool Thermostat Logo
Posted on Apr 21, 2010
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Replaced Bryant Thermostat model TSTATBBNB001 with Honeywell model RTH3100C. Old terminals labeled R,G,Y1,W2,W1(O,B),Y2,C. Heat pump wired with Red wire to R, Green wire to G, White wire to W1, Black to C, Yellow to Y1. No other wires used. System is Bryant Heat Pump. Wired new as manual shows with terminals E,AUX,Y,G,O,L,R,B,C. Wired Black to C, Yellow to Y, Green to G, Red to R, and White to Aux. Also put jumper from Aux to E per install manual.. Air cond. seems to work fine. When try to heat the fans come on but blows cold air, no heat!. Am I wired correctly! Thanks
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
4210
Points
27
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
I have a rth3100 that i installed programed it ac came on the next day went off and wont come on it was cycling on and of. After new one was installed dont have power to it
http://www.ps2netdrivers.net/wiring.diagram/honeywell.rth3100c/
Here you can find all about Honeywell RTH3100C like wiring diagram and other informations. For example: thermostat wiring diagram, installation manual, installation, thermostat, wiring, manual.
Honeywell RTH3100C manual (user guide) is ready to download for free.
1helpful
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
1helpful
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Installing a new termostat
Depends on the brand of unit you are running.
Brand and model number please.
Most are on "O".
Hook it to "O" and run the unit. if it runs correctly in Heat and Cool, you are OK.
If not switch it to the "B" terminal.
2answers
Heat will not shut off
Take white off of Aux, and attach it to L
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
2helpful
2answers
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
1helpful
4answers
Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Top Honeywell Measuring Tools & Sensors Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
