The most common cause for unfindable paper jams in epson inkjet printer is a lever or light sensor that has come loose. normally you can remove the upper housing by unscrewing four screws (2 back, 2 inside) and get a better view on the insides. if you see a small part in black plastic which seems not to be in place, try to reposition it, make sure all cables are reconnected when closing the machine and test it. however, before you do this, check if your printer is still under warranty. if it is, it's strongly advised to turn to an authorised repair center. then a pro will take care of your printer without any cost for you...
It only takes a few particles to cause the jam light to come on.
Please update printer firmware/driver
try in other pc
check the spring below cartridge..might be faulty
