If the lower drive of your Ryobi weed eater has broken off about an inch, it may be possible to repair it. However, the extent of the damage and the specific model of your weed eater can affect the repairability. Here are a few steps you can take to assess the situation:
1. Examine the broken piece: Carefully inspect the broken lower drive and determine if it can be reattached or if it requires replacement. Look for any other damaged components as well.
2. Check for replacement parts: Visit the official Ryobi website or contact their customer support to check if they offer replacement parts for your specific model. If the broken lower drive is available as a separate part, you can order it and replace the damaged one.
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
