I have a WTW5200S top loading clothes washer. After a load is done it looks like there's no water in the tub but if you move it around by hand you call still hear some sloshing around. Is this normal or should all the water get pumped out at the end of the cycle?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Testimonial: "Thanks!"
