SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
SOURCE: VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
SOURCE: VHS tape will not eject.
Hi and welcome to FixYa,
Initially, the top cover must be removed. Theis would allow you to:
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
