Fossil AU4003 Wristwatch Logo
Posted on Apr 20, 2010
New battery went in fine and watch is running but I can't get back to snap into place
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
2answers
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
1helpful
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    16helpful
    5answers
    SEKONDA: HOW DO YOU REPLACE THE SNAP ON BACK COVER?
    Sorry, but your hands (especialy fingers) aren't strong enough. Nothing personal- just confirming the fact. My hands can handle 50 ATM casebacks, but I would say this is more expierence than strength.
    OK, back to business: align the winder groove first and make sure this side of caseback sits in properly in case. Then use your thumbs to push the opposite side of caseback in, supporting the watch by your palms and knees. Do not try to push the caseback in bit by bit going all around the caseback. This sort of action will never work.
    So, align the groove, support your palms by the knee(s) and push the opposite (to the groove) side of the caseback in to the watch case by one, but strong attempt with your thumbs. It should snap in.
    If this doesn't work, you will need to ask the watchmaker to close the watch.
    NB: Watchmakers are using specialized press for closing watch cases wich do not require any strength at all.
    Rate me, please.
    How do i change the battery in a timex wr 30 m watch
    remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
    2helpful
    3answers
    Expedition WR50M
    I had the same problem. The thing that was most frustrating is that I have a standard tool to remove and install screw in watch backs, but Timex in its infintie wisdom, decided to make this model withta snap-in back.
    I tired usinga a set of adjustable locking pliers with rubber claw covers. I tried holding one side with finger and thumb while using the pliers on the other to no avail.
    robatbath's answer about jewelers having a special press led me to a solution. I just happened to have (2) 1.25" steel washers with 1/4 inch holes. I placed one on the face and one on the back. This way I could use the locking pliers (with rubber covers on) to press in the center of each side. The back snapped in fine. You can get washers and pliers at any hardware store.
    72helpful
    15answers
    HELP !! can't snap armitron watch cover back on
    Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
    Jan 20, 2008 • Watches
    1helpful
    Skagen ladies watch
    izzi, I assume you have a snap back back that won't snap back in place. I had the same problem with a Timex EXpedition. The solution should be similar. See my post" http://www.fixya.com/support/t190459-watch_battery_replacement and also the site I reference there. http://www.online-batteries.co.uk/whichbattery.shtml Good luck, Richard
    Top Fossil Watches Experts
    john h
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
