Logitech Harmony 880 LCD Remote Control Logo
Anonymous Posted on Apr 20, 2010
Cradle does not keep remote charged. Remote beeps occasionally when just sitting in cradle.
Anonymous
Level 2:
Novelist:
  • Expert 101 Answers
  • Posted on Apr 20, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
101
Questions
0
Helped
39001
Points
147
See the information in the link.
My Harmony 890 won't charge correctly http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/popup_adp.php?p_sid=undefined&p_lva=undefined&p_li=undefined&p_faqid=9169 once the information is filled out, email logitech with the answers and the shipping/login information to see if they can assist you with this. Another things i would advise checking is the battery and what condition it is in.
Testimonial: "I found that on the Logitech site and have an email into them. Thanks Betsy"
1helpful
My one year old Logitech Harmony 890 is not charging the battery. I have replaced the battery and watched it drop from full charge to 1/4 charge about 2 days. I have verified there is 8.5V at the pins in...
Generally there are three possibilities (apart from the battery going bad) that can cause your remote not to charge:
1) Some folks have reported that the battery is not sitting tightly enough in the battery compartment. You can try folding a small piece of thin cardboard and place it between the battery and the back of the compartment. This will push the battery towards the front of the compartment and create a tighter connection against the contacts.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). If all else fails, you can open the remote and check to make sure that the plug is completely seated or attempt to push the terminal contacts slightly farther out. However, most people have found that altering the height of the contacts on the charging cradle is a better way to go. If you want to open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the clamshell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Once you are done exploring, simply realign the two halves and snap them back together. Good Luck!!
2helpful
Battery will not recharge. Completely dead. Do I
Are you sure it's the battery and not the charging cradle? Make sure you try some of the following before you buy another battery. If it ends up you do need another one, you can pick up an OEM battery on Ebay for around $10. Just be careful that you get a battery that will charge in the cradle. There are some knockoffs from China that will ONLY charge using a special wall charger, so read the ads carefully.
Generally there are three possibilities (apart from the battery going bad) that can cause your battery not to charge:
My harmony 890 remote stopped working; wouldn't
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear additional beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with alcohol or a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
1helpful
I have a harmony 880 remote. Won't charge now.
3) If you still have trouble after you have tried everything above, there may be a loose connection inside the remote itself. There is a very small plug that connects the charging terminals on the remote to the battery compartment. In some cases, this plug can become loose (especially if the remote has been dropped). Opening the remote and checking to make sure that the plug is completely seated is another thing to check if all else fails.
1helpful
My harmony 880 will not charge
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show2_bing.gif should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact.
1helpful
Dead. When I put on charger I get no response
Remote is not recharging when placed in cradle even after cleaning posts with alcohol.
2) There have been reports of problems with some of the charging cradles in which the remote does not make sufficient contact with the contacts in the cradle. To ensure that the remote begins to charge, place it in the cradle and listen for a single beep. The slide show should start and then, after a few moments the screen should darken. If you hear two beeps at any time, it means that the remote has lost contact with the charging cradle and has 'woken' and is no longer in charging mode. Wiggle the remote to ensure that it is sitting in the cradle and making contact. There are also some fixes that can be done of the cradle itself, including opening it up and adjusting the height of the contacts. Others have had luck cleaning the contacts on the remote and the cradle with something more 'high test' than alcohol - a contact cleaner like DeoxIT. Still others have actually sanded down the plastic surrounding the contacts on the outside of the remote in order to bring them closer to the cradle contacts.
3helpful
Harmony 880 not charging in cradle it's there all nite and in the morn it still only has 1 bar
2helpful
Base of Harmony 880 is plugged in and lit up. When I put the remote in the charger nothing happens. It doesn't even light up. I have cleaned the contacts. Remote will not turn on anything.
Generally there are three possibilities (apart from the battery going bad and the remote cradle not getting power, both of which are infrequent) that can cause your battery not to charge:
My remote wont charge? even on charger - it says
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
