My kenmore elite washer is giving me an error message F 02, not draining
Here is what the manufacture says about F02 - Below this are my comments
If
the drain time exceeds eight minutes, the water valves are
turned
off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed,
then
four minutes later the “F/02” error code will be
displayed.
Possible
Causes / Procedure
1. Check the drain hose and make sure it is not
plugged
or kinked.
2. Unplug washer or disconnect power.
3.
Check the electrical connections at the pump and make
sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5.
Plug in
washer or reconnect power.
6. If the above does not correct the
problem, go to step 7.
7. Unplug washer or disconnect power.
8.
Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or
small articles like baby socks you may have a plugged up pump. To access
the pump lay on the floor and remove the 3 screws holding the lower
panel of washer on. Pull down and out on the panel to remove. Lay out a
lot of towels under the unit, I mean a lot... Look in the center for a
white cap about the diameter of a large cup, it will have a handle on it
to turn, turn this left(counter clockwise) to unscrew. This will
unscrew and pull out, but be careful when it comes out so does all the
water. Clean out the trap that is in your hand and anything you see or
feel in the sump area the trap came from. Reassemble and test. If this
does not work you will more than likely need a new drain pump, that is
the component on the right of that trap you just cleaned out.
Testimonial: "You are a Guru! Thank you so much for informing us about the "hidden" trap which housed an ankle sock, .90 & lint! works like a charm now!!"
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
