Posted on Apr 20, 2010
Need a parallel to usb cable for Panasonic printer KX-P2023 to connect to new dell cpu
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
7787
Points
61
2helpful
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
2helpful
3answers
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
P2023 prints garbage with vista
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
1helpful
3answers
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Panasonic KX-P2023 Matrix
hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
Panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
I NEED TO GET A DISK SO I CAN ADD TO MY COMPUTER. PANASONIC KX-P2023
If your looking for the printer driver, it should already be in the computer. Windows 2000, XP and Vista all come with the KX-P2023 driver pre-loaded. If you can't find it, you can use just about any of the KX-P2000 series drivers that are pre-loaded wqith Windows.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
