Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Apr 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jul 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
13705
Points
34
Most likely you are in reverse with the key in the mow forward position only. turn key to the reverse mode or put the gear selector to forward mode.
Ned White
Level 3:
  • Master 2,100 Answers
  • Posted on Apr 20, 2010
Ned  White
Master
Level 3:
Answers
2100
Questions
0
Helped
810907
Points
6188
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
2answers
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Blades wont ingage on my craftsman lawn tractor #917.274811?
After hitting a tree root, blades will not cut when I press to engage
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
4helpful
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
2helpful
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
