Humidifiers Logo
Posted on Nov 04, 2017
I have a Sunbeam Health at Home humidifier and need help w/usage
I have a Sunbeam Health at Home humidifier Model #1117 and cannot find the instruction book to tell me how to use it. I have had this product for a few years and cannot find the instruction book that came with it so I can use it for my allergies. I would like to receive the instructions on the computer if you have it available.
4 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jan 26, 2008
SOURCE: Honeywell Humidifier HUT102m
I've been having problems with this unit since purchase in December 2007.
To fill, unscrew the cap with the spring loaded plunger. It may be tight, but it has two slots which you can turn like a screwhead using something wide enough (eg, a spoon) for leverage.
My problem is that this thing leaks badly. The fit of the cartridge is terribly designed. The one supplied is different from the one depicted in the unhelpful manual, which is silent on where the cartridge should fit. It will fit in one spot, but it will not sit flush with floor of the unit; it rocks and the water holding top rocks with it. The supplied cartridge appears to be an attempted and unsuccessful fix of a problematic design.
Even without the cartridge, this unit still leaks.
A web search shows others complaining about leaking. Hate to say it, but another example of lousy American design... but it sure is pretty!
Haven't been able to raise the manufacturer "Kaz" on the phone.
Anonymous
  • Posted on Jan 23, 2009
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Anonymous
  • 114 Answers
  • Posted on Aug 20, 2009
SOURCE: I need technical instructions explaining how the
to get the instructions. you can go to www.jardenstore.com . click on the holmes on the main page. in the search bar on the left type in your model the hm1865. click on the unit which should be the 2nd picture. right below that picture it has the manual. it will download in adobe reader.
Anonymous
  • 742 Answers
  • Posted on Jan 03, 2010
SOURCE: I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
2answers
Need the manual for Sunbeam humidifier swm2311
El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
2answers
I recently found a Sunbeam humidifier without a manual. 1. What filters go in it? 2. Do you have a manual? I think I'm missing a part to this humidifier. Thanks.
Yes Truly Blessed, we do have all the manuals if you can find the model number on the label. They are all listed here on our website.
Home Comfort ... - Sunbeam Canada Instruction Manuals
https://www.sunbeam.ca > home-comfort > humidifiers
Instruction Manuals for Home Comfort Products, Humidifiers. ... SUL1410-CN - Sunbeam® Ultrasonic Cool Mist Humidifier Instruction Manual EN-FR · 1361-705 ...
You can get filters from us
Humidifier Filters & Accessories: Find your filter ... - Sunbeam
https://www.sunbeam.ca > en_CA > home-comfort > hu...
Find your filter for your Sunbeam® humidifier to keep the air in your house comfortable, water treatment tablets offer a light scent to the mist from your humidifier.
and also from our Amazon resellers
Sunbeam Humidifier Filter - Amazon.ca
https://www.amazon.ca > Sunbeam-Humidifier-Filter
Results 1 - 48 of 849 - IOppWin 6 Pack Humidifier Filters Replacement for''A'' Holmes Filters, Compare to Part # HWF62, HWF62D,Compatible with Sunbeam Cool ...
How many amps does the sunbeam health at home humidifier use?
Multiply the amps time the volts = watts. .49 x 220 = 107 watts.
Hello! please advise what will happen if unit is left running & is out of water?
If the float valve in the water tank is not working properly, by shutting off the unit when it's empty, Leaving it running will probably burn up the pump motor.
The tank empty light won't shut off even with water in the tank.
The float valve is probably stuck. Empty the water out of the reservoir and clean the tank with 50/50 White Vinegar and water.
Hello...i have a sunbeam filter free warm mist humidifier,and i put the water in and turn it on but it doesn't seem to be working. All the lites are on but nothing and it's brand new too never been used.
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
Can I get a replacement tank for Sunbeam humidifier model #SWM5251
Hi, unfortunately there's nowhere to purchase a replacement tank online. You can buy a new humidifier from Walmart for $25 when they replenish their stock:
http://www.walmart.com/ip/Sunbeam-Warm-Mist-Humidifier/12356384
Or you can get one for $29.29 branded as Holmes instead of Sunbeam from DrillSpot.com:
http://www.drillspot.com/products/1347166/jarden_consumer-heater_hum_swm5251-um_small_room_warm_humidifier
eBay also currently lists 3 of these humidifiers, being sold for $34.99 each (also branded as Holmes):
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=swm5251&_sacat=See-All-Categories
2helpful
2answers
I'd like to clean my sunbeam warm mist humidifier
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
Top Sunbeam Humidifiers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
