Default Printer IssueThe wrong printer is set as the default. See the image below for an illustration.
What to doOpen the
Printers or
Printer and Faxes folder and locate the correct printer icon. To do this:
- -In Windows XP, click Start > Settings > Printer and Faxes (or Start > Control Panel > Printers and Faxes).
-In Windows Vista, click Start > Control Panel > Hardware and Sound > Printers.
- Right-click on the printer icon, and click Set as Default Printer. A check mark displayed above the printer icon now identifies it as your default printer.
- Try printing again.
Topic 3: Printer is "Offline"The printer is set to
Offline and the printer icon appears washed-out. See the image below for an illustration.
What to doOpen the
Printers or
- Right-click on the printer icon, and select Use Printer Online.
Topic 4: Printer is not ReadyThe
printer is in an "Intervention Requested" state (e.g. paper jam, paper
out) but no Windows print error notification message is displayed.
Explanation
The
print job cleared the print queue. This means the print queue icon has
disappeared from the notification area ('systray') of the task bar. The
printer is holding the job, however, until the the printer is returned
to a ready state.
What to doCheck the printer
LCD, or operator panel menu, to verify that the printer is in a ready state. If not, return it to the required status.
Topic 5: Printer is PausedThe printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation
This is typically an end user error. Dragging the mouse cursor over the print queue icon in the notification area will reveal
(1,2,3) document(s) pending for (User name).
What to do
Double-click
on the print queue icon to open the print queue. (This may also appear
as a small printer icon in the lower-right notification area of the task
bar.)
Click on Printer in the upper left-hand corner of the menu bar.
Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Topic 10: Windows Print Spooler IssueA problem with the Windows print spooler is preventing successful printing.
What to tryStop and start the Windows print spooler. To do this:
- -In Windows XP, click Start > Control Panel > Administrative Tools > Services, click on Print Spooler, click on Stop the service, and then click on Start the service.
- -In Windows Vista, click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. Right-click on Print Spooler, and then click Stop. Finally, right-click on Print Spooler again, and then click Start.
Remove the first print job from the print queue. To do this:
- Double-click
bar.)
- Click on the first job listed so that it is highlighted.
- Click on Document in the top menu bar.
- Click on Cancel.
- Click Yes when you see: "Are you sure you want to cancel the selected jobs?"
Click here for illustration.
Topic 11: Other IssuesOther possible causes of a print job not printing include:
- -USB connection problem if locally connected only.
- -Firewall issues preventing communication.
- -Workplace
virtual private networks (VPNs) preventing communication. VPN tunneling
may be required to ensure successful communication. Enabling this
feature may require network administrator approval and assistance.
- -Document formatting.
- -Driver settings.
- -Application-specific issues relating to the application's Printer Setup.
Topic 12: Last ResortIf you have tried all of the above suggestions to no avail, try the following:
Reboot your computer and try printing again.
Turn the printer off and on, and then try to print again.
Install a different printer driver, e.g. PCL, PostScript, HBP, or XPS driver.
I have been using this printer for a long time. All of a sudden, it won't print. I've tried uninstalling, reinstalling, troubleshooting instructions, etc. Nothing.
