You may try some recovery software to rescue the files on your handy recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the recorder in case the original files(your recordings) are overwritten.
I downloaded the TRIAL version of Wondershare Photo Recovery Software (windows version). It successfully scanned the SC card in my handy recorder (in this case, a Zoom H4n), finding all 22 wav files I had mistakenly deleted from the recorder. SUCCESS! The software reported that it could save all of my files, but I needed to purchase the software ($29.95 for a single user license). The registration code came to my email account instantly, and as soon as I entered the registration code into the trail version software, it saved all 22 of my wav files to a new folder of my choice on my computer HD (I could have selected some other destination. I AM VERY HAPPY. (I ran this using Windows XP). (The trial version of Wondershare Photo Recovery Softwarer that i downloaded to my Mac OSX 10.4.11 did not seem to run with my version of the Mac OS) ---professor MB of the Univ. of Washington.
Yes, there is a way for you to recover
these deleted files on this SD card. So, don't worry!
The deleted files on a memory card are not
actually erased as we think. They are only saved there and become invisible.
So, in order to get them all back, you
should act carefully.
1). Do not format this SD card, if you
still want to save your data completely. The formatting process always may
increase the difficulty of successful data recovery and cause data loss for
you.
2). Do not save anything new on this card
in case of data loss.
3). Download a SD card data recovery
freeware to save your wanted data back successfully at first and then format
this drive to fix its problems.
Try to take chances with this SD card data recovery freeware that
would completely get back all your deleted files back:
http://www.freeware-fix.blogspot.com/2013/03/sd-card-not-formatted-error.html
Note: Do not forget to format this card after completely get back your
data.
Remember to back up everything important on
different drives or cards in the future.
In these days, the formatted process often
could not completely erase the contained data on a SD card.
In other words, you always do have chances
to get back these deleted data back after the formatting process as long as
you've not overwritten it with any new file.
Try to use a SD card data recovery freeware
to retrieve your deleted files back from this formatted SD card.
http://www.formatrecovery.blogspot.com/2013/02/recover-data-after-formatting.html
Note: Next time, you should never save all
the important data on only one hard drive.
Read more information of this SD card data recocvery freeware here:http://blog4mark.blogspot.com/2012/12/sd...
Accidental formatting of memory card is quite common cause that happens in some unfortunate scenarios and results in loss of files from SD card. However, you don't worry much about it as it is still possible to recover SD card WAV files until they are overwritten by some new data. So it very important to stop using SD card immediately after the formatting for saving new files and also avoid reformatting of memory card to prevent permanent loss of your valuable WAV files. Recover SD card is one such tool that perfectly helped me to restore WAV files, other audio files, video files, generic photo types and also RAW photo file formats supported by latest DSLR cameras. Once you also try to download the free version of this tool and check its performance. I am sure that it will restore your WAV files.
Card Data Recovery is professional photo recovery software to recover deleted, lost, corrupted or formatted
photos, videos, and auido files from various memory cards, such as, SDHC card, SD
card, CF card, memory card, memory sticks, USB devices, digital cameras, hard
drives, and zip drives.
SOURCE: Corrupted WAV file will not play or transfer to computer
yes!...
after try, try and try again... i have the solution now!
my english is very bad but i will try write good...
ok... i use one file recover (have many softs this type in internet...) i used this: R-Studio
try this and all will be ok!
good luck for yours!
Abimael - Lgm
[email protected]
SOURCE: I can't change the file types on my Zoom H4n.
I discovered that if I have the stamina button engaged (by the batteries) I cannot change the record type, either by the button or through the menu (the rec setting does not give the option). If I take stamina off -- which only takes effect after a restart -- the rec settings work normaly, both through the button and the menu!
SOURCE: deleted a file by accident. Can you recommend
Deleting won't make your files deletedactually. They are just not visible but still in the hard drive which you savedthem at. You can rely on some data recovery programs to help you find themback. You can try Card Data Recovery. Just install this program on your computerand use the function "all recovery", after a while your deleted fileswill be back soon.
Yes, you should connect your SD card or your recorder (as removable drive) to PC. Then you can try to recover your files with Easy Drive Data Recovery software:http://www.munsoft.com/EasyDriveDataReco... It uses unique modern algorithms to recover files that other software either recovers incorrectly or is unable to detect.
