Question about Janome Mini Compact
I just bought a janome mini sewing machine. I
I just bought a used janome mini sewing machine. I cannot get the top thread to
pick up the bobbin thread. There is no lint anywhere or stuck thread. The needle
does not look bent. The machine also did not come with a manual. I don't know how to change the needle.
    New Friend:
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Janome sew mini needle not picking up bobbin thread.
Hi: Is this a needle provided with the machine as new? What type of fabric are you sewing... have you tried a different fabric? Is the bobbin placed into the machine correctly with it unwinding in the right direction?
Aug 10, 2012 | Janome SEW MINI Mechanical Sewing Machine
Needle wont pick up bobbin thread
Aug 20, 2009 | Sewing Machines
SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Jul 28, 2009 | Janome Mini Compact
Janome sew mini will not pick up bobbin thread
Oil the machine first. Then, determine whether or not you need any parts at all.
Jul 03, 2009 | Janome Mini Compact
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Machine will not pick up bobbin thread
Sounds like your needle is in too far and it not allowing the needle to go down far enough to pick up the thread.
Apr 20, 2009 | Janome Sewing Machines
Janome mini sewing machine not picking up thread
Is it under warranty? A dealer should be able to check it out without cost to you. Do you have the bobbin in properly.
Oct 18, 2008 | Janome Mini Compact
Janome M100 mini sewing machine
Providing you have checked to make sure the needle is in correctly, if the machine will not pick up the thread then the machine will need retiming.
Jan 21, 2008 | Sewing Machines
Janome Mini Compact Logo
1,281 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
