After basic trouble shooting I found that both av-1 and av-2 work fine. I've rerouted the sat box through the av-2 port. still no response through the cable port.
any ideas?
Your problem is either bad tuner in TV, or Sat. box converter out (chan. 3,4) bad. Test on another TV.Your problem is either bad tuner in TV, or Sat. box converter out (chan. 3,4) bad. Test on another TV.
You can't post conmments that contain an email address.
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Did you try it on BOTH the SAT and Video 2 optical ports? Still not working? Could be the Optical cable is bad.
Does your Cable Box also have a coaxial digital ouput? It looks just like a standard RCA connector but says Digital somewhere near it. Try one conductor of a standard audio cable from it to the "DVD" coax connector. Select DVD to hear it.
If it still doesn't work jump into the Cable Box setup to make sure it's output is set up properly.
I would recommend using the coaxial digital option if you have it.
1) The cable isn't special or expensive like the optical cable is; a garden-variety RCA cable works just fine.
2) You have virtually unlimited distance to work with in the house.
3) You don't have to be so darned careful with it as with optical.
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
