Radio Communications Logo
Posted on Apr 18, 2010
Manual for ranger professional bluetooth cb - Ranger TR-966 CB Radio
1helpful
I need a manual for texas ranger free spirit cb model tr127fs manual. Can you help me?
I would try using the manual for the TR 127GK or the DX models and see how they work out for you. I did a google search and came up with nothing.
Where can i get the ranger professional bluetooth ppr -rbt1 repair?
if its still under warrentee then send it back to where it was made. If not send it to a place like Bells cb in Fl. or another reputable shop. Inquire with them before you send it to them and they will tell you how to send it.
Need user manual for a Ranger TR 127FS
Service manual is on the CBTricks.Com website. Look in the index for TR-127GK. This the same radio under the covers. This should suffice as an owners manual also.
....Don at NTCB, Inc.
1helpful
How do you get cobra 29ltd bluetooth in discoverable mode to match up with my cell
To pair the CB to your cell phone Press and HOLD the Bluetooth button on the microphone until you hear a beep. The Bluetooth light on the CB should be blinking on and off. You now have 5 minutes to link with the cell phone. You will need to push buttons on your cell phone to complete the pairing process. If you are not sure how to setup a Bluetooth device on your cell phone, then refer to the owners manual or contact your cell provider. During the pairing process you will need to enter a passcode. The passcode is 0000. After successfully pairing, the Bluetooth light on the CB will blink every 10 seconds to indicate Bluetooth standby mode. After 1 minute it will stop blinking
2helpful
Need user manual for ranger rci-6900f turbo
Here is a link that goes to RCI for the complete manual for this model----let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
http://www.rangerusa.com/pdf/man6900f.pdf
4answers
I need a manual to base station CB Ranger rci-2990. Can you tell me where to download or purchase this manual. Thanks
http://www.rangerusa.com/websupport.html
http://www.worldwidedx.com/cb-band-cb-radios/18036-manual-rci-2990-a.html
you may find some help with these sites
4helpful
2answers
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
11helpful
3answers
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
