Sylvania LD370SS8 37 in. LCD Television Logo
Posted on Apr 17, 2010
Need the Direct TV RC-64 code for the Sylvania LC370SS09 T.V.
I have tried the codes provided online and other codes that I have searched on the web. Nothing works. I have tried the codes for Phillips, Funai, Magnavox and others. Having to use 2 remotes is a pain. Any codes available? It should be a 5 digit code.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
263
Points
11864 worked for me (posted somewhere) after checking about 50 codes for sylvania, funai, magnovox etc.
I need codes for my etec tv for a directv remote
This TV brand is not listed with direct tv remote control. Do a code search method. If there is a pre-programmed code in the remote, you can setup your TV by this method. For more details, visit the site 'Electro-help'. All details about code search method is described here in detail. Type in "electronicshelponline.blogspot" into your browsers' search box and click search. Pull up older posts there.
4helpful
Cannot turn it on with the Directv remote. What should I do ?
Hello
Codes to check with Vizio TV with [Direct TV RC-64 for WEB Universal remote control] are:
10864, 10885, 11499, 11756,
11758
OK.
Need remote codes for the sylvania tv model 6427gg
Hello
Three digit universal remote codes for Sylvania TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit universal remote codes for Sylvania TV are:
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
3helpful
2answers
Can't program my remote to my Sylvania tv! I've tried every code they had for it. It's a 13 inch tv/dvd combo and its a comcast remote. Please help!
Although you didn't explain what brand of universal remote this was for, all universe remotes have a code search option for this situation. Check the manual for your specific remote control for more details.
Often manufacturers of multiple brands will use the same infrared (IR) codes for all of their brands. For example, Panasonic and Quasar share the same codes as their parent company is Matsushita Industries. In your case Funai is the parent company of Sylvania and the parent company of Magnavox so you might want to try the Magnavox codes before doing a code search. As Funai also manufactures televisions for Toshiba and Sharp, so try those codes as well.
Tv codes
What problem are you having?
Try using Mitsubishi codes if the Polaroid codes for Direct TV. Mitsubishi code: 10178
Toshiba code 678 works for a Polaroid TV model FLM-1514B
Polaroid tv/dvd combo is 1991.
The dvd code equivalent of that code is dvd 1480.
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
Make and model of your TV would help...thx
3helpful
2answers
32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
3helpful
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
10helpful
3answers
I need a code for an Emerson Model LC320EMX television that can work with my DirecTv remote. I've tried all the ones that were given by DirecTv & none of them worked. Has anyone had the same problem?...
I was just reading everyone’s comments regarding not being able to find the Emerson LC320EMXF 32′ LCD TV code for the Comcast DC50X Digital Transport Adapter. I’m using the Sylvania code of 11864 and the Comcast DC50X remote seems to work fine. Hopefully it’ll work for you as well.
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
Sylvania LC370SS8 , I have tried to program the TV with our Cable
Sylvania TVs are made by Funai Corp. You should try any Funai codes that are listed for the Synergy V remote. Alternatively, you can try the code search method, point and search. See http://help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC-U62CDR/index.htm#Point_and_Press_Programming for the details. One Synergy V remote code list is available in this copy of the manual: http://help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC-U63CDR/RC-U63CDR.pdf . I found the codes for Funai to be 047 048 157 168 211 .
I hope this helps.
(For my TV, the search all codes is often better for universal remotes. The brand name codes listed didn't work; searching all codes found an exact match for all the features that I use.)
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
