Yamaha RX-V663 Receiver Logo
Posted on Apr 17, 2010
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
5755
Points
24
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
I have Yamaha RX V667 AV receiver in that in sound test surround back right speaker not working. Surround right sound coming directly jumped to surround back left channel how to fix the problem please...
That can only happen I think if you have the speakers connected to the wrong terminals. Check the connections and make certain they are right, plus the wire is good and not touching any parts it shouldn't
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
3answers
I'm trying to connect my yamaha rxv592 reciever to my samsung smart tv LCD. The reciever doesn't have a optical option or hdmi. I love surround sound. Please help
You need something like this:
Digital to Analogue 5.1 converter:
http://www.ebay.com.au/itm/like/131104197505?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107&chn=ps
I have never used one of these before, but i have worked in the audio industry and if this device works as advertised it will suit your needs.
RX-V665 turns on for a second then turns off
don`t open it yet
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Need a manual
Simple web searches get answers faster than waiting for one of us to pick up the question.
Try "Yamaha RX-V665 manual"
Just a question, not a problem yet. I do not have speakers for my RX-V665 and do not know what to get. My mid and rear speakers will be mounted in the ceiling (a suspended ceiling) I am worried about...
Why does impedance concern you? This receiver can be configured for loads as low as 6 ohms. The front speakers can be 4 ohms if you use a single pair.
It's all explained on page 106.
This receiver should be able to drive most quality speaker systems. Anything from ub/satellite sets to 6-matched speakers plus a sub will work. It seems you have a choice already made for surrounds. Whatever yoy choose, you have to balance performance, aesthetics and price. The Yamaha is probably not a limitation. Get what you can afford and place to your satisfaction.
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
1helpful
Is there a code so I can connect my Pioneer PD F505 to my Yamaha RX V665?
What do you mean - code? It's hardware, connect it via its optical digital cable.
RX-V665 Yamaha reciever has been working great. Use it for surround sound and outside, zone two speakers. Recently started turning off during movies. I run blu-ray through receiver. When playing Star Wars...
You may find a solution by doing some of the things I have tried - see below
I recently puchased this model to replace an older Yamaha system that also had this shut-off problem. The new RX665 system has the same problem but I check the impedance setting using the instruction in the manaul anyway. The problem persists. I have check all speaker wire to make sure nothing was touching. I did find one wire touching on the center speaker but the problem persist.
Since the problem followed me when I moved and with a new amp, I am beginning to think I am have a speaker that's causing this - maybe the sub.
How do i connect my cable tv to my yamaha rx-v665? i do not have a cable box
If your tv has an audio out jack attach a rca cable from that to your receiver any audio input.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
