NetGear DG834G Router Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i pair my iphone to my netgear router? the model number is dg834gu v5
Charles East
Level 2:
  • Expert 331 Answers
  • Posted on Apr 16, 2010
Charles East
Expert
Level 2:
Answers
331
Questions
Helped
136290
Points
728
Are you trying to connect WIFI? "pairing" is a bluetooth function. If the router has not already been configured for WIFI, then your iphone should see a local wireless network called Netgear. You should be able to connect to it with your iphone simply by selecting it and answering the security question. If it has already been configured, you should make sure it was setup for WPA or WPA2 (NOT WEP) When it was configured, it should have been setup with a passphrase (key code, encryption key) which you need to intially provide on your iphone to make the connection. Its pretty straight forward.
2answers
Pairing Router to Extender.
Please double check that each of your products are compatible with each other by either calling Arris or Netgear. You also review the netgear setup instructions after you've made the call if they're compatible.
This is the phone number for Arris: 1-877-466-8646
Thank you.
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
I put in the default login but it wont direct me to the netgear page
NetGear WGR614 router..... what version? v4 or v5 ..etc
MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON CUTTING AFTER ABOUT 10MINS FROM REBOOTING.WHATS THE PROBLEM
There are many reasons why this might be happening.. You could try the following steps..
First connect the modem directly to the computer and see of the problem persists..if yes contact your internet service provider..if the problem doesnt show up with modem then please follow the below steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
4helpful
I have a Netgear DG834GU v5 modem and have forgotton the password for Wi Fi, I wish to use it on my ipod. Could you help me find a solution? Regards Nat
Press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
Use this method for cases when the administration password or IP address is not known. These steps restores the router setting to factory defaults. (e.i. administration password to admin and the IP address to 10.0.0.2.
eds6524
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
L G Wireless Problems. Comunication between netgear v5 and laptop
Some notebooks are not compatible with some routers. Netgear is not that user friendly. But it is not a bad router. you can do one or all of the following:
  1. Replace the router to a newer more user and compatible model. Upgrade to a newer "N" router.
  2. Download a network program to connect you. Network Magic is a good one. Cheap and works really well.
  3. Have a network pro come set it up properly and test your system.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
