My sony walkman nwz-e344 digital media player froze yesterday during use and wouldn't pause, turn off or anything. Now it won't turn on at all and when I plug it into my computer via usb cord it won't even show on the computer that it's plugged in. I pushed the reset button on the back, and the screen turned off for just a second and then turned off. What's wrong with it?
SOURCE: sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
SOURCE: My fully charge sony media player NWZ-E435F will not turn on
Hey...Just remove the Battery for 2mins, reload and Power ON again...It may work
-sai
SOURCE: My Sony Walkman NWZ-E435F wont turn on at all even when plugged in with my USB
I had the same problem. For at least a week. Try pressing the reset button. The reset button won't delete your music, videos, pictures, etc. Just resets your system. If that does not work then i don't know what else to tell you.
SOURCE: NWZ-B135 stuck on 'Walkman' logo, but won't go to play mode.
U need to upgrade the firmware,you need to download the firmware from here: http://support.sony-europe.com/dna/downloads/firmware/firmware.aspx?site=odw_en_GB&m=NWZ-B135&f=FRM_NWZ_B13x_f after downloading,run it and then connect the player to system while holding the "volume -" button...it should be detected and the firmware would be restored.
SOURCE: My son has a Sony Walkman mpw NWZ E344. It is
it happens when drivers gone mix. try to Re install
drivers of the mp 3 on pc or laptop. you can do via drivers CD
