Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My micro sd card when i plug say format but as i format it giving error of "Data write protected" but my micro sd card have no lock or other lock and the company of my sd card is Red bridge.Plz solve this problem.thank you.
Anonymous
Level 2:
Sergeant:
  • Expert 209 Answers
  • Posted on Apr 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
209
Questions
0
Helped
34432
Points
619
Hello there!
Well somehow data on your usb flash is write protected, maybe before you locked part of your usb pen drive and losted that encryptor software on your usb.
Solution is next, find any software for formatting usb flash memory sticks, force format it and there you go. Thats about it! =)
Sincerely
Aleksandar Adzic
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
2answers
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Method 2
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
5helpful
5answers
I have msdc card errroro i want to format
buy a card reader.put your msdc in the card reader slot.connect the card reader to computer andyou can format it just like a pendrive.
1helpful
2answers
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
2answers
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
25helpful
4answers
To recover my 2gp micro sd memory card
you can recover memory card with card recovery software like asoftech data recovery, download the software with link below
Memory Card Recovery Software
1helpful
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
