Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Apr 16, 2010
Washer will not open, drain or spin.
Washer went off balance & gave an error code. Restarted. Same thing twice more. Unplugged it twice. Tried every cycle. Will not spin, drain, or open. Our clothes are held hostage. What do we do?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1169
Points
9
If the error code is SE it needs 2 be manually drained
I have an LG washing machine. It has a PF code. Simple things don't fix it
As LG states in troubleshooting section,
If your unit is displaying a "PF" error code, it means you've experienced a power failure. This may occur if the power supply to the washing machine is interrupted during a cycle from a power outage. To fix this, simply restart the washing cycle
LG Washer - Error Code List ' LG USA Support
3helpful
2answers
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
First washer would not fill tried later it started got to spin stop will not empty water tried drain and spin button still wont run help thank you happy hoildays joe thomas
Suds detection & long drain error codes indicate a problem with the water draining out or too much soap is being used. If the unit is not draining good then I would suspect a problem with the pump or control board. Please see the images provided for more details. Press stop twice to reset the control.
We just received an F2 error on the washer? how
Well it depends is it an F2 or an F02.. Two different codes.. an F2 code or and (F ) code could be electrical variables "F" Variables [F4 to F16] (Electrical Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START.
"FO2" (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Hope that helps I just went to www.sears.com/parts typed your model you were missing a diget on the end picked one located the owners manual on manage my home and went to trouble shooting all else fails it says calls for service.
My whirlpool duet washer will rotate to balance
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
To solve this:
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
thanks.
1helpful
2answers
Error code F70 on Whirlpool frontload washer WFW9600
Welcome spammailmd
You said, you tried to use the delayed wash last night but when we went to it this morning we had error code F70. There is a small possibility that the door was not closed properly, but we forgot to check. We opened the door, closed it and restarted it on a non-delayed wash and it started just fine. The manual for the washer is not very descriptive with the error codes, it simply says to restart and if that doesn't work call the repair man (what is this a microsoft windows machine?).
Whirlpool codes:
“F” codes other than F20, F21 or F22
Re-select cycle and press START. If the problem remains,
call for service.
Let me know that it works for you or if you have any questions.
Thank You.
Please remember to leave a rating
Huuum
4helpful
2answers
GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
23helpful
6answers
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
