Dear Sir,
plz use this step for restore
To use System Restore to restore Windows XP to a previous state, follow these steps:
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section
1. Insert the restore disk into your computer's DVD/CD
drive. Prior login to your user account is not required.
2.Reboot your computer. Watch the boot screens and wait for
the onscreen prompt to press any key. If you do not get a prompt, reboot your
computer once more and skip to step four.
3.Press any key to boot from CD when prompted to do so. You
will now be taken to the first screen in the restore process. Follow the
onscreen prompts to finish restoring your machine.
4.Change your BIOS settings, if necessary, to boot from your
CD drive first. Common options for entering the BIOS include pressing
"ESC," "DEL" or "F12" on your computer's first
boot screen. If you don't know how to get to the BIOS, check your computer's
documentation for instructions. Once inside the BIOS, set the primary boot to
CD-ROM and save your changes. Exit the BIOS and wait as your computer reboots
and begins the restore process.
If
this answer helpful please vote me.
Good
luck.
Thanks for using FixYa
