Sylvania 6520FDE 20 in. TV/DVD Combo Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our tv doesn't have sound or picture
Our Sylvania tv doesn't have sound and no picture. The screen is black and white Fuzzy screen.
Anonymous
Level 3:
  • Master 371 Answers
  • Posted on Apr 16, 2010
Anonymous
Master
Level 3:
Answers
371
Questions
0
Helped
147664
Points
1106
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
White fuzzy thin vertical lines appear on screen. The picture is fine, but the lines are in front of it. Is this something than can be repaired?
Hello can you post a picture of your tv set with the fuzzy white lines thank you so I can give you the best sound advice.
Sylvania tv problems
Check and replace its main chroma IC. It is defective. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
2helpful
My tv blacksouts with no picture but has sound?
tried with resetting doesn't work?totally black screen or has a white screen display?
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
12helpful
My Sylvania 32" just had the entire screen go
My Sylvania 32" just had the entire screen go white. There was still sound but the picture was gone and just the white screen. Any ideas?
1helpful
I was just given a 6842PE sylvania tv. when i plugged it in and connected the satellite the screen is very fuzzy and has a black 1 in line straight down the middle of the screen. i can see the outline of...
the 1inch black line is either a buffer board gone bad or the ribbon cable from the plasma screen to the buffer board, the snowy picture could be many things, including y-sus, xsus or tuner boards
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Fuzzy picture
I plug in my ps3 to my old tv and what appeard to me were the buzzing screen and its in black and white but the sounds is working perfectly just the buzzing fuzzing screen will it hav the same problem with HDMI Component on the HDMI TV ? PLZ help me Thx
2answers
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
