Where do I find instructions, pictures and diagrams describing how to remove the glass from an Epson Perfection V200 flatbed scanner? I need to clean off the fog on the inside side of the glass that has been created by off-gassing from electronic components.
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
SOURCE: How do I scan a slide photo / negitive on my epson
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
