Canon LaserCLASS Fax 710 Printer Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code #0005 what does it mean? and possible causes?
Erica turner
Level 2:
Novelist:
  • Canon Expert 76 Answers
  • Posted on Aug 02, 2019
Erica turner
Canon Expert
Level 2:
Novelist:
Answers
76
Questions
28
Helped
134942
Points
309
Canon Printer Error Code 005
  • Uninstall and reinstall the printer software.
  • Check the cable connector. If it is damaged get a new one.
  • Also, check the connector plug and clean it.
  • Properly mount the cable connector on the wall outlet and connect it tightly with the system and the printer.
  • Check the requirements of the system and make it compatible with the Canon printer.
Anonymous
Level 3:
President:
  • Master 405 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
President:
Answers
405
Questions
0
Helped
205380
Points
1407
Found the cause of the error, basically the other end is having trouble most likely poor line conditions.
##005 [ TX ] Failed G12 reception during G2 transmission.
A. Cause: Other party cannot properly receive the G12 signals due to poor line conditions.
Solution: Have the other party boost their transmission level so they can properly receive G12 signal.
B. Cause: Other party confused by echo and does not send G12.
Solution: Have the other party lower their transmission level so they will not receive echo signals.
Canon irc6800 error code E000061-0005
Have you checked corona assembly wheter the wire is not damaged/missplaced? From my memory this error means either that or problem with voltage on drum in general. (corona and/or laser shutter issue)
3helpful
My washer wont drain and Im getting a 03 code appearing what does this mean
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
1helpful
OE error code on my LG washer
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system.
1helpful
READING A CODE OF OE WAT DOES THIS MEAN?
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine has an OE error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
78helpful
6answers
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Need tv library codes to connect universal media so xbox media re
Aiko 0047
Aiwa 0433, 0247, 0247, 0433, 0446
Akai 0044
Amtron 0038
Anam 0248, 0038, 0071, 0116, 0122
AOC 0005, 0022, 0050, 0062, 0126
Apex 0119, 0141, 0155, 0438
Audiovox 0038
Bell & Howell 0008, 0043
Benq 0227, 0198
Broksonic 0133, 0134, 0248
Celebrity 0044
Citizen 0005, 0038, 0047, 0055, 0062, 0085, 0156
Colortyme 0005, 0013, 0062
Contec/Cony 0248, 0016, 0019, 0038
Craig 0038, 0248
Crown 0038, 0063
Curtis Mathes 0005, 0664, 0043, 0053, 0062, 0085, 0152, 0156
Daewoo 0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237
Daytron 0005, 0062, 0156
Dimensia 0664, 0152
Dumont 0001, 0005
Durabrand 0439
Electroband 0044
Electrohome 0005, 0037, 0044, 0062, 0066, 0071
Emerson 0005, 0011, 0012, 0014, 0015, 0016, 0020, 0021, 0035, 0038, 0043, 0052, 0056, 0062, 0069, 0124, 0129, 0137, 0156, 0248, 0486
Envision 0005, 0062
Fisher 0025, 0040, 0043, 0115, 0245
Fujitsu 0015, 0199, 0200, 0201, 0202, 0203, 0669
Funai 0015, 0038, 0248
Gateway 0207
GE 0664, 0005, 0018, 0032, 0037, 0059, 0062, 0071, 0074, 0104, 0147, 0152, 0248, 0469, 0488, 0489
Goldstar 0005, 0016, 0023, 0045, 0050, 0062, 0066, 0077, 0096, 0143, 0156, 0249
Hallmark 0005, 0062
Hisense 0125
Hitachi 0003, 0005, 0016, 0019, 0030, 0060, 0062, 0064, 0067, 0081, 0095, 0101, 0106, 0124, 0136, 0213, 0238, 0473, 0496, 0173, 0174, 0175, 0412, 0165, 0171, 0205
Infinity 0063
Janeil 0120
JBL 0063
JC Penney 0005, 0018, 0019, 0032, 0037, 0664, 0041, 0045, 0050, 0055, 0062, 0074, 0077, 0085, 0102, 0104, 0143, 0152, 0156, 0249
Jensen 0005, 0062
JVC 217, 0435, 0010, 0016, 0019, 0024, 0033, 0051, 0056, 0060, 0074, 0132, 0142, 0217, 0435, 0470, 0475, 0477, 0497, 0503, 0504, 0505, 0216
Kawasho 0005, 0044, 0062
Kenwood 0005, 0062, 0066
Kloss Novabeam 0036, 0038, 0042, 0120
KTV 0038, 0080, 0137, 0156, 0248
LG 0050
Loewe 0063
Logik 0008
Luxman 0005, 0062
LXI 0664, 0041, 0043, 0062, 0063, 0104, 0117, 0152, 0249
Magnavox 0521, 0005, 0027, 0029, 0034, 0036, 0042, 0055, 0062, 0063, 0066, 0097, 0098, 0222, 0522, 0523, 0524
Majestic 0008
Marantz 0005, 0048, 0062, 0063, 0064, 0249
Megatron 0062, 0064
Memorex 0008, 0043, 0050, 0062, 0249, 0442, 0525
MGA 0005, 0025, 0026, 0037, 0050, 0062, 0066, 0076
Mitsubishi 0005, 0025, 0026, 0037, 0049, 0050, 0062, 0066, 0076, 0223, 0526, 0527, 0666
Montgomery Ward 0008
Motorola 0071, 0110
MTC 0005, 0050, 0062, 0085
Multitech 0038
Multivision 0070
NAD 0041, 0062, 0106
NEC 0005, 0013, 0050, 0062, 0071
NET-TV 0163, 0192
Nikko 0047, 0062
Onwa 0038, 0248
Optimus 0106
Optonica 0054, 0110
Orion 0012, 0129, 0441
Panasonic 0135, 0150, 0215, 0063, 0071, 0074, 0127, 0135, 0150, 0215, 0528, 0530, 0566, 0228, 0228, 0170, 0179, 0180, 0211
Philco 0005, 0016, 0027, 0029, 0036, 0042, 0050, 0055, 0062, 0063, 0066, 0071
Philips 0005, 0016, 0027, 0032, 0036, 0042, 0046, 0055, 0063, 0066, 0071, 0214, 0235, 0299, 0540, 0541, 0543, 0545, 0548, 0550, 0553, 0554, 0522, 0560, 0562
Philips Magnavox 0413, 0299, 0413, 0521, 0540, 0545, 0548, 0550, 0552, 0553, 0554, 0522, 0524, 0523, 0560, 0562
Pioneer 0005, 0062, 0068, 0072, 0075, 0106, 0124, 0408, 0411, 0197, 0158
PlasmaSync 0169
Portland 0005, 0047, 0050, 0062, 0156
Price Club 0085
Prima 0139
Prism 0074
Proscan 0664, 0104, 0152
Proton 0005, 0016, 0062, 0065, 0249
Quasar 0071, 0074, 0080, 0127, 0228, 0565, 0566
Radio Shack 0043, 0152, 0248
Radio Shack/Realistic 005, 0016, 0038, 0664, 0043, 0054, 0062, 0143, 0156
RCA 0436, 0664, 0153, 0664, 0005, 0022, 0050, 0062, 0066, 0071, 0087, 0092, 0094, 0100, 0104, 0107, 0109, 0118, 0124, 0130, 0146, 0152, 0153, 0248, 0436, 0568, 0488, 0486
Runco 0001
Sampo 0005, 0062, 0138, 0143, 0156, 0163
Samsung 0005, 0016, 0050, 0053, 0062, 0066, 0085, 0093, 0102, 0114, 0143, 0156, 0231, 0401, 0184, 0177, 0210, 0159, 0160, 0208, 0406, 0181, 0182, 0183, 0184, 0185, 0193, 0665
Sansui 0131, 0129, 0131, 0441
1helpful
2answers
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
2helpful
What does OE mean on a Hitachi washer??
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
old marine
old marine
ZJ Limited
ZJ Limited
