Tip & How-To about Computers & Internet
How to use your iPod to move your music to a new computer
***** THIS DOSE NOT WORK WITH IPOD TOUCH OR IPHONE*******
open itunes connect ipod
from the summer page at the bottom
put a check next to manually manage music and video
ok - close itunes
go to : start > my music > itunes
right click on itunes folder and select copy
go to : start > my computer > choose the drive of the ipod > then right click >Paste
take your ipod to a new cpu
connect ipod
go to : start > My Computer > choose the drive for the ipod > find itunes folder > right click on it choose cut
go to : Start > my music
If there is an existing itunes folder in here delete it unless there is music in the library - this will remove the existing library
right click > paste
after you paste it - restart the computer
( download itunes if you have not already )
open itunes and all your music and playlist will be here
if you get a message the the library was created from an old library then follow this step to resolve
http://support.apple.com/kb/ht1451
Computers & Internet Logo
how to unlock iPhone 4
I'm sure you have forgotten your iPhone password so that need to unlock iPhone. It's a common situation. You can solve this problem by means of iTunes or iCloud. Just follow below steps.
-Use iCloud
  • (1). Open and log in iCloud on your laptop or PC that is connected with the iPod touch.
  • (2). Click Find My iPod and let it start to search and connect with your iPod touch APP.
  • (3). When iCloud is connected to the iOS device, its position will be fixed and shown on the map, then click the option at the upper right of Clear iPod and follow the next indication.
-Use recovery mode
  • (1). If iTunes prompts you to enter the password, and you cannot remember it, try to use the recovery mode to unlock iPod touch without password. Given that you are using recovery mode, you are not able to backup before resetting device, which means that you are going to lose all the data on the iPod touch.
  • (2). Close iPod device completely. Hold Power button and slide the Power Slider to close iPod touch.
  • (3). Connect your iPod touch to the computer and use iTunes to enter into recovery mode.
  • (4). Open iTunes and hold Power+Home buttons long before the logo of Apple appears. Then click Recovery Mode.
  • (5). Click Set Up As New iPod Touch. Initialize the settings of your iPod touch and import the backup and restore the data.
For more methods, check: How to Unlock iPod Touch
i cant unlock my iphone 3gs
If you have forgotten iPhone passcode and it resulted in failure to unlock your iPhone. You can follow below steps to unlock it with iTunes or iCloud.
-Use iCloud
-Use recovery mode
getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
mp4 player touch
Update your iPod Software to at least 3.xx version
This is important as lower version of the software would not allow you to download any applications. You can do so from iTunes. Once you connect your iPod Touch or iPhone to the computer and start iTunes, it will tell you if there is a newer version of the software to upgrade. Just follow the instructions.
  • ** Restart your iPod/iPhone
    This step is just to reboot your iPod system to make sure the new software is in effect.
  • Step 3 ** Download applications aka games
    Make sure your iPhone/iPod Touch is connected to the internet. On your iPod touch/iPhone home page, there will now be a link labeled: 'Apps store'. Select that link. Now, you are free to browse the many applications and games that iTunes has to offer. Some games are free while others may require you to pay. .
  • Step 4 **Install the application aka game
    Once you have selected a game to install, tap the box that says, "free" in the right hand corner. It will then read, "Install". Tap the box again. Now, wait for the application to install on your home page.
  • hope this helps out a bit
    3answers
    how to sync .ipa files from comp to iphone thru itunes ?
    when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
    Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
    Step 1: Connect iPhone or iPod touch
    1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
    2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
    Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
    For more information about syncing iPhone with your computer see the iPhone User's Guide:
    On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
    On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
    For more information about syncing iPod touch with your computer:
    On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
    On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
    Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
    The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
    You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
    Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Grand Canyon Tech
    Grand Canyon Tech
