HP OfficeJet 7110 All-In-One Thermal Printer Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print cancelled will not clear. How do I clear
Print cancelled will not clear. How do I clear this in order to go into copy mode?
Dr Tony
Level 2:
Novelist:
  • Expert 142 Answers
  • Posted on Apr 15, 2010
Dr Tony
Expert
Level 2:
Novelist:
Answers
142
Questions
0
Helped
38891
Points
295
Please perform the following steps if the message is on the unit diaplay:
1. Disconnect the unit from the computer. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
:) Dr Tony
Is there another way to stop unwanted copies from being printed if the reset/stop button does not work?
If printing from your computer...yes. Go to the cancel print function on your computer and cancel the print. That will stop more copies being printed once you have hit cancel.
Otherwise you would need to switch the power off to the machine and remove any paper. Then turn it on again and play with the controls until you can clear the print memory back to zero.
How to put C460FW Samsung printer in "tech Mode"
(From ready to copy/Just finished warming up from power off)
Press the following buttons in order
Menu, Back, Left arrow, Right arrow, OK, Stop/Clear, Menu
How do i stop print on brother hl2040
Right click with mouse on the print icon in bottom right of pc ,select cancel print in list, then go to printers in control panel and clear all print jobs in your printer list.
2answers
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
2answers
Us.mg1.mail.yahoo.com is stuck in my printer que and I cannot cancel or delet it nor can I print anything else
Unplug your printer and leave it unplugged for at least a minute. Also reboot your computer. It will clear the printer queue!
May 05, 2011 • Yahoo Mail
2answers
Code on control panel says 5A6
You are in Sabbath mode.
Press and hold the clock button for 3 seconds to cancel unless you are Jewish. In which case it will cancel itself in 24 hours.
2helpful
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
1helpful
Cs-2114 all dark copies
if you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
k24674
Grand Canyon Tech
Grand Canyon Tech
