Question about Bunn VPS Coffee Maker
Leaks from top
After pot fill and water reheats it boil over and out the top
    President:
  • 1,618 Answers
Either the thermostat is turned up to high or damaged.
Posted on Apr 15, 2010
6ya staff
SOURCE:
L have been given one of the origanal tupperware rice cookers to use with boiling water. please can you advise on how to use it
get a pot big enough for the container
fill the container with the desired amount of rice
place in pot , fill to over the top with water and bring to the boil and cook for the required time
when finished
remove the container and place rice on a plate or in a bowl
Sep 12, 2018 | The Kitchen Appliances - Others
Churchs bunn. Vps 04275-0013 started heating water till steam comes out fill hole. Causing water to drip everywhere....thinking a thermostate is not opening causing steam
Over Boiling or constant heating of tank water is an indication of a shorted thermostat (or out of calibration). Call your vendor for service. (especially if this equipment is on loan.)
*** the following is for information only. Repairs should be performed by a qualified Bunn Tech. ***
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
PS; There is a slight chance that your thermostat is set too high. There is a dial on the thermostat that can be turned counter clockwise to lower the temperature of the brewing water. Water should be about 190-205 F for coffee. Tea drinkers want 210 F which is too close to boiling point of water. If your in the mountains (+2000 feet) then the boiling temp will lower. Was it possible the brewer came from a low (sea level) location and moved to higher altitude? Then the setting is off and must be set lower (a fine adjustment). But note that if your on the top of a high mountain (like Haleakala, Hawaii) then it has to be set a lot lower and you will only get luke warm brews at 9,000 feet!. Adjust the knob clockwise to get it to boil. Then back it off counter-clockwise a bit till it stops boiling. Make another brew to check if the reheat comes to a boil but stops after a minute or so. It should not boil on longer than 2-3 mins. Back it off a bit more if it does. Brew again to check. If none of this works then you will need to replace the thermostat. If your at a really HIGH altitude location, then you will need a specially adapted high altitude brewer. Call your coffee vendor for advice.
Feb 16, 2018 | Coffee Makers & Espresso Machines
Water overfill
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
Apr 04, 2014 | Bunn A10 Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
How do you open an alessi pepper mill to refill it?
You will need:- Large cooking pot- Grinder- Tongs- Hot pads or oven mitts (mitts are recommended)- CautionPut the grinder into a large cooking pot. Fill the pot with water until the grinder is completely submerged. Make sure that the plastic parts of the grinder do not touch the bottom or sides of the pot. On the stove-top bring the water in the pot to a boil. Once the water is boiling turn off the heat. The grinder is now very hot and full of hot water so be careful not to burn yourself. Using tongs remove the grinder from the water and hold it upside down to drain most of the trapped water back into the pot. Now turn the grinder upright again to trap any remaining hot water. Using your hot pads or oven mitts grasp the glass part of the grinder in one hand and the plastic part with the other hand and pry them apart. Let both parts of the grinder dry completely then refill it and snap the plastic top back on. These make great grinders for other spices as well such as coriander. Enjoy!
Aug 09, 2011 | Coffee Makers & Espresso Machines
I have a bunn coffee maker, BT10-13. The reserve water takes very long to reheat after making a pot of coffee. Thus I can't make a second pot of coffee for a long time.
Are you rapid firing your coffee maker?Not designed to do that.. If the water heated that fast it would boil dry if you ever left it unattended and on. The reservoir is heated with the time it takes to drink a full pot taken into consideration for reheating.. If you are serving 20 cups with a 10 cup machine, Expect a delay, especially if you are refilling with cold tap water. Sorry.
Jun 30, 2009 | Bunn B10 Coffee Maker
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Oct 29, 2007 | Bunn NHB Coffee Maker
Bunn VPS Coffee Maker Logo
132 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
Marvin
Marvin
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
