I have a frigidaire gallery frontload washer model GLTF1040AS0 for about 7 years. Work fine until today. On the spin cycle with a NORMAL load the machine start to make big noise. After a closer inspection the drum inside seem to miss some shock absorbtion. the drum keep banging up and down/front side to side. If i spin it empty the drum spin relatively smoothly. The machine work normaly for the washing part. the drum turn like before . Both upper sping seem ok. Im wandering if the two shock bellow might be the probleme or if the problem is in the drum. Both shock look ok. no crack . grease on 1 but not in big quantity. I can turn the drum by hand freely. Some minor squeek but nothing i dident hear before. Thx for your advice :)
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Testimonial: "Ok that was my guess. That answer was lightning fast. Thx you very much. Will remove it. test it and post if the problem is fix. Thx again"
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
