How do I push or pull the pin out? Here is the pic: http://i.imgur.com/Galus.jpg There is a circle around the pin. If I pushed the pin, then the circle comes out. (Like the red circle in pic) I couldn't push the pin anymore. Then I pushed the circle, the other side of pin would come out a little bit. I tried to pull out the other side of pin. It feels like there's a spring inside. I could pull out a little bit, but no more. If I let go, it returns to its original position. Any help would be appreciated.
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Hi, On most watches they have two pins that you have to remove with a small flat screw driver.
These pins are spring loaded so watch out. You will need some patence to do this. Good luck
Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
Thank you for contacting FixYa.
The best place you can contact for replacement would be Movado itself by following the following link: http://service.movadogroup.com/care.cfm
Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
mcdevito75 here, Best Bet, look for a small watch repair shop imn your area to svae on cost, special tool available on ebay is needed since it's a Movado let the shop remove links to re size.
