There is excessive frost build up in the freezer. At the bottom of the freezer, the water pools up and forms ice sheet on the bottom. This is a side by side refrigerator. All Suggestions welcome.
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
frost block builds up inside freezer
I'm getting a sheet of ice building up in the bottom of the freezer compartment
build up of ice in bottom freezer
Ice keeps building up in the bottom of the refrigerator side of my samsung side by side refrigerator/freezer
ice build up on bottom of freezer
