The person I am speaking with does not hear me (He is deaf).
The microphone function does not appear to be working. I have adjusted
the volume and that's not the problem (You must speak as well).
I have plugged both jacks (microphone and speaker) into my PC hard drive
and am using my PC to talk on Skype (You cant plug even a single jack in the hard drive).
Problem solved!
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices
Properties window locate the SOUND PLAYBACK box and click the VOLUME button.
Make sure that there is not a tick (check-mark) in the MUTE box against
microphone in the list of devices and that the volume slider is at the top of
the scale.
Also make sure that the MUTE ALL box
isn't checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls).
NOTE if microphone is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
'show the following volume controls' and then click OK.
That should be it.
