Question about Canon Pixma MP500 All-In-One InkJet Printer
The print quality of my printer is excellent; however, the back of the document has a long 3/8" vertical line of black ink. How can I eliminate this problem?
    New Friend:
    Problem Solver:
  • 6 Answers
It sounds like you need to perform a bottom plate clean on the printer.
If your using XP(other os' mileage may vary, but are similar):
Start
Control Panel
Printers and Faxes
<right click canon printer>
<left click properties>
<left click maintenance tab>
Bottom Plate Clean.
Hope this helps.
Posted on Apr 14, 2010
6ya staff
SOURCE:
Epson printer 1400, is printing vertical blue lines through my prints. How can I eliminate them?
If the lines are vertical to the direction of the printhead movement, you need to clean the paper rollers and the small "pizza wheels" of your printer. Also check for any traces of stuck paper in the paper path. I recon you ars not using genuine inks, right? Try to slow down your print speed by selecting a best quality setting.
If the lines are parallel to the printhead movement, your printhead is either clogged our stuck.
Jan 07, 2014 | Epson Stylus 1400 InkJet Photo Printer
Can the printer print with just a black ink cartridge?
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 19, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Black lines interferring with printouts
Not really sure what you mean by lines on your documents, but you could have excessive ink spilled on your printer rollers.or the page bar,,this can usually be remedies by taking the printer apart and carefully cleaning all of the surfaces the paper run against.
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
53 people viewed this question
Clive
Clive
old marine
old marine
Ekse
